smtp.office365.com
SethThellos
J'essaie de configurer le smtp d'office365 mais j'ai systématiquement des erreurs.
Je me réfère à la doc officiel Microsoft : https://support.microsoft.com/fr-fr/off ... 6c4ac95353
Donc le configure ainsi :
Serveur : smtp.office365.com
Port : 587
Tests effectuées :
CHANGEMENT CLASSE
Vérification SSL : Désactivée
Préfixe : Aucun
Classe : IsSenMail
2022-05-09 13:03:32 Connection: opening to smtp.office365.com:587, timeout=5, options=array ( 'ssl' => array ( 'verify_peer' => false, 'verify_peer_name' => false, 'allow_self_signed' => true, ),)
2022-05-09 13:03:32 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:03:32
2022-05-09 13:03:32 Connection: opening to smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:03:36 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:03:36
CHANGEMENT CLASSE
Préfixe : Aucun
Classe : IsSMTP (défaut)
 2022-05-09 13:04:17 Connection: opening to smtp.office365.com:587, timeout=5, options=array ( 'ssl' => array ( 'verify_peer' => false, 'verify_peer_name' => false, 'allow_self_signed' => true, ),)
2022-05-09 13:04:17 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:04:17
2022-05-09 13:04:17 Connection: opening to smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:04:21 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:04:21
CHANGEMENT PREFIXE + CLASSE
Préfixe : SSL//
2022-05-09 13:05:57 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array ( 'ssl' => array ( 'verify_peer' => false, 'verify_peer_name' => false, 'allow_self_signed' => true, ),)
2022-05-09 13:05:57 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:05:57
2022-05-09 13:05:57 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:06:00 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:06:00
Préfixe : SSL//
Classe : IsSendMail
 2022-05-09 13:05:03 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array ( 'ssl' => array ( 'verify_peer' => false, 'verify_peer_name' => false, 'allow_self_signed' => true, ),)
2022-05-09 13:05:04 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:05:04
2022-05-09 13:05:04 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:05:08 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:05:08
CHANGEMENT VERIFICATION SSL + PREFIXE + CLASSE
Vérification SSL : Activée
Préfixe : Aucun
2022-05-09 13:20:53 Connection: opening to smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:20:53 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:20:53
Préfixe : Aucun
Classe : IsSendMail
2022-05-09 13:21:15 Connection: opening to smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:21:15 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
Préfixe : TLS//
2022-05-09 13:22:10 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:22:10 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:22:10
Préfixe : TLS//
Classe : IsSendMail
2022-05-09 13:22:38 Connection: opening to ssl://smtp.office365.com:587, timeout=5, options=array()
2022-05-09 13:22:38 Connection failed. Error #2: stream_socket_client(): unable to connect to ssl://smtp.office365.com:587 (Connexion refus�e) [/home/yoehsds/gestsup/components/PHPMailer/src/SMTP.php line 389]
2022-05-09 13:22:38
Préfixe : SSL//
2022-05-09 13:22:10
Préfixe : SSL//
Classe : IsSendMail
2022-05-09 13:22:38
Je ne comprends donc plus rien ....
ai-je omis qq chose ?
Capture d’écran 2022-05-09 152454.jpg (69.42 Kio) Vu 8267 fois
il semble que vous ayez un défaut de communication réseau entre le serveur GestSup et le SMTP, vérifier vos firewalls.
SethThellos
Il semble surtout que ce soit OVH et Microsoft qui ne s'entendent plus.
SethThellos
Bonjour, je constate que le protocole SMTP d'office365 demande la fonction STARTTLS, est-ce possible d'avoir une ajout dans le plugin mail afin de pouvoir enfin rentrer en prod ?
Merci encore pour le taff de ouff !!
Bonjour, pouvez-vous transmettre une impression écran de votre connecteur SMTP.
SethThellos
Bonjour, le voici.
Mais comme j'ai écrit plus tot, j'ai testé TOUTES les options mélangées possibles.
Sans titre.png (51.86 Kio) Vu 8121 fois
afin d'isoler le problème pouvez vous tester de configurer temporairement, le connecteur SMTP de la webdemo afin d'isoler un problème avec votre hébergement OVH.
Cd
SethThellos
HUM .....
Ca provient bien d'OVH (je m'en doutais un peu).
Cependant, j'avais le même souci avec WP sur le même mutualisé, nous avons bypass le problème en créant une inscription d'apps dans AZURE AD.
Est-ce possible de développer ce même type de connexion pour GESTSUP ?
Capture d’écran 2022-05-23 120941.jpg (177.35 Kio) Vu 8115 fois
L' OAuth de Microsoft sera intégré d'ici la fin de l'année.
SethThellos
Bonjour, ce qui veut dire que la connexion LDAP AAD sera aussi prise en charge ?
