Visibilité des tickets avec service
il s'agissait uniquement de retélécharger le patch 3.2.47 puis écraser les fichiers sur votre serveur, pas de modification de la base de données.
Merci de transmettre les logs d'erreurs Apache.
Anthonyv
Même sans l'import SQL cela ne fonctionne pas non plus :
[Tue Feb 20 13:35:34.592283 2024] [php:error] [pid 2879938] [client 77.205.55.30:49385] PHP Fatal error: Uncaught Error: Failed opening required './vendor/components/php-gettext/gettext.inc' (include_path='.:/usr/share/php') in /var/ww>
[Tue Feb 20 13:35:53.450282 2024] [php:warn] [pid 2880026] [client 77.205.55.30:49395] PHP Warning: Undefined variable $Ah in /usr/share/adminer/adminer.php on line 1787, referer: http ://51.178.41.231/adminer.php?username=gestsup&db=ge>
[Tue Feb 20 13:36:20.834481 2024] [php:warn] [pid 2879940] [client 77.205.55.30:49455] PHP Warning: require_once(./vendor/components/php-gettext/gettext.inc): Failed to open stream: No such file or directory in /var/www/html/localizati>
[Tue Feb 20 13:36:20.834532 2024] [php:error] [pid 2879940] [client 77.205.55.30:49455] PHP Fatal error: Uncaught Error: Failed opening required './vendor/components/php-gettext/gettext.inc' (include_path='.:/usr/share/php') in /var/ww>
[Tue Feb 20 13:36:23.061065 2024] [php:warn] [pid 2879942] [client 77.205.55.30:49456] PHP Warning: require_once(./vendor/components/php-gettext/gettext.inc): Failed to open stream: No such file or directory in /var/www/html/localizati>
[Tue Feb 20 13:36:23.061115 2024] [php:error] [pid 2879942] [client 77.205.55.30:49456] PHP Fatal error: Uncaught Error: Failed opening required './vendor/components/php-gettext/gettext.inc' (include_path='.:/usr/share/php') in /var/ww>
[Tue Feb 20 13:36:53.131964 2024] [mpm_prefork:notice] [pid 658] AH00171: Graceful restart requested, doing restart
ocsinventory-server: Bad setting. `SCAN_TYPE_IPDISCOVER` is not set. Default: `ICMP`
ocsinventory-server: Bad setting. `SCAN_ARP_BANDWIDTH` is not set. Default: `256`
ocsinventory-server: Bad setting. `IPDISCOVER_LINK_TAG_NETWORK` is not set. Default: `0`
ocsinventory-server: Bad setting. `SCAN_TYPE_SNMP` is not set. Default: `ICMP`
ocsinventory-server: Bad setting. `GENERATE_OCS_FILES_SNMP` is not set. Default: `0`
ocsinventory-server: Can't load SOAP::Transport::HTTP* - Web service will be unavailable
[Tue Feb 20 13:36:53.342435 2024] [mpm_prefork:notice] [pid 658] AH00163: Apache/2.4.57 (Debian) OpenSSL/3.0.11 mod_perl/2.0.12 Perl/v5.36.0 configured -- resuming normal operations
[Tue Feb 20 13:36:53.342454 2024] [core:notice] [pid 658] AH00094: Command line: '/usr/sbin/apache2'
Pouvez-vous vérifier la présence du fichier suivant sur votre serveur :
Vérifier également les droits.
Anthonyv
Cela fonctionne ! Merci !!
