U4GM WoW Midnight Demonology DPS Guide
jhb66
Missing a Tyrant window by three seconds can make an otherwise clean pull feel awful, especially after you spent real time farming enchants, consumables, or even checking where to WoW Midnight Gold before raid night. Demonology is not hard because the buttons are mysterious. It is hard because the spec punishes sloppy timing.
Demonology Warlock Basics in Midnight Season 1
Why the spec hits so hard
Demonology Warlock is built around one plain idea: stack demons, then make them hit harder during Demonic Tyrant. Wild Imps, Dreadstalkers, Felguard, and Tyrant damage all scale together, so your best pulls rarely come from one huge spell. They come from a crowded battlefield where every summon is active at the right moment.
Personally, I like this design more than the older “press cooldown, watch number” style. It feels earned. If you rush Tyrant with only a few imps out, the cooldown still looks flashy, but the damage log tells on you immediately.
Stats and gearing priorities
Haste is usually the first stat I check because it smooths the whole engine: faster Shadow Bolts, quicker Demonbolt spending, and fewer awkward gaps before Hand of Gul'dan. Mastery sits close behind since it directly improves demon damage. Critical Strike is fine. Versatility is mostly the defensive comfort stat, useful in high keys but rarely exciting.
Priority
Why it matters
Haste
Faster shard generation and cleaner setup windows
Mastery
More damage from pets and Tyrant
Critical Strike
Better overall damage consistency
Versatility
Extra toughness for punishing Mythic+ pulls
Demonology Warlock Rotation and Tyrant Setup
The practical burst checklist
For Demonology Warlock, the best Tyrant setup is less about memorizing a perfect script and more about avoiding obvious waste. Still, a checklist helps. I would rather follow a slightly imperfect plan every pull than improvise into a bad Tyrant.
1) Enter the setup with enough Soul Shards, ideally close to five, without overcapping.
2) Cast Call Dreadstalkers on time. Delaying it feels harmless, but it pushes the whole burst window out of shape.
3) Spend shards on Hand of Gul'dan to build Wild Imps, then use Demonic Tyrant while those demons still have meaningful duration left.
4) After Tyrant lands, keep casting. Do not admire the army. That mistake is more common than people admit.
Mythic+ adjustments
Mythic+ asks a different question: can your damage arrive before the pack melts or the tank starts kiting? Implosion becomes a real decision here, not a random AoE button. Use it when imps are near expiration, when a large pull needs instant burst, or when enemies are about to move out of pet cleave range.
Oh, and one more thing: do not hold every cooldown for the “perfect” pull unless your group actually plays around that plan. In a coordinated key, saving Tyrant for a double pull makes sense. In a pug, sitting on it for ninety seconds can be pure comedy.
Demonology Warlock Mistakes, Myths, and Survival
Common myths that cost damage
The biggest myth is that more imps always means a better window. Usually, yes, but not if you delay Tyrant so long that Dreadstalkers expire or the boss becomes untargetable. Another shaky idea is that Demonbolt procs should always be spent instantly. From what I have seen, holding one briefly to finish a clean shard cycle can be smarter.
Do not overcap Soul Shards during movement.
Do not cast Tyrant before your demon count is ready.
Do not forget external buffs such as Bloodlust or Power Infusion.
Defensives and spec choice
Damage is only useful if you live long enough to deliver it. Dark Pact is excellent before predictable spikes, while Unending Resolve is better for dangerous overlaps where an interrupt, stun, or heavy hit could ruin the pull. Honestly, Warlocks get away with greed that would flatten other casters, but that is not permission to ignore mechanics.
Demonology will not be the best answer for every boss. Heavy cleave and planned burst favor it. Long spread encounters may push some players toward Affliction, while short burn phases can make Destruction tempting. Before your next raid, test one dungeon route, track Tyrant timing, and if gearing is slowing your prep or you compare prices for WoW Midnight Gold buy options, keep the main goal simple: make every Tyrant arrive with an army, not an apology.
