Lors de l'installation de Gestsup sur une machine virtuelle sous Windows Server 2022, avec le serveur Wamp en version 2.4.59 et PHP en version 8.3.6, je rencontre des difficultés pour lancer la configuration de Gestsup.
Merci beaucoup
Problème d'installation Gestsup
pouvez-vous transmettre le log d'erreur Apache.
--- File cleaned up by Wampserver installation or update ---
::1 - - [25/Apr/2024:15:29:04 +0200] "GET / HTTP/1.1" 200 21128
::1 - - [25/Apr/2024:15:29:05 +0200] "GET /wampthemes/classic/style.css HTTP/1.1" 200 2972
::1 - - [25/Apr/2024:15:29:05 +0200] "GET /wampthemes/popupmodal.css HTTP/1.1" 200 3477
::1 - - [25/Apr/2024:15:29:05 +0200] "GET /wampthemes/classic/img/gifLogo1.gif HTTP/1.1" 200 2681
::1 - - [25/Apr/2024:15:29:06 +0200] "GET /wampthemes/classic/img/pngFolderGo.png HTTP/1.1" 200 694
::1 - - [25/Apr/2024:15:29:06 +0200] "GET /wampthemes/classic/img/pngWrench.png HTTP/1.1" 200 741
::1 - - [25/Apr/2024:15:29:06 +0200] "GET /favicon.ico HTTP/1.1" 200 202575
::1 - - [25/Apr/2024:15:29:11 +0200] "GET / HTTP/1.1" 200 21128
::1 - - [25/Apr/2024:15:30:11 +0200] "-" 408 -
::1 - - [25/Apr/2024:15:37:24 +0200] "GET / HTTP/1.1" 200 21128
::1 - - [25/Apr/2024:15:40:24 +0200] "GET / HTTP/1.1" 200 21300
::1 - - [25/Apr/2024:15:41:00 +0200] "GET /Gestsup/install HTTP/1.1" 500 648
::1 - - [25/Apr/2024:15:41:08 +0200] "GET /install HTTP/1.1" 404 302
::1 - - [25/Apr/2024:15:41:24 +0200] "GET /Gestsup/install HTTP/1.1" 500 648
::1 - - [25/Apr/2024:15:41:46 +0200] "GET / HTTP/1.1" 200 21300
::1 - - [25/Apr/2024:15:41:53 +0200] "GET / HTTP/1.1" 200 21300
::1 - - [25/Apr/2024:15:42:53 +0200] "-" 408 -
::1 - - [25/Apr/2024:15:45:45 +0200] "GET /Gestsup/install HTTP/1.1" 500 648
::1 - - [25/Apr/2024:15:46:45 +0200] "-" 408 -
::1 - - [25/Apr/2024:15:55:19 +0200] "GET /Gestsup/install HTTP/1.1" 500 647
::1 - - [25/Apr/2024:15:55:20 +0200] "GET /Gestsup/install HTTP/1.1" 500 647
Le fichier de log s'appelle apache_error.log sous WAMP.
Pourrez vous transmettre une impression écran de l'arborescence Windows c:\wamp
[Thu Apr 25 15:28:37.545892 2024] [mpm_winnt:notice] [pid 4240:tid 328] AH00455: Apache/2.4.59 (Win64) PHP/8.2.18 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Thu Apr 25 15:28:37.545892 2024] [mpm_winnt:notice] [pid 4240:tid 328] AH00456: Apache Lounge VS17 Server built: Apr 4 2024 15:03:17
[Thu Apr 25 15:28:37.545892 2024] [core:notice] [pid 4240:tid 328] AH00094: Command line: 'c:\\wamp64\\bin\\apache\\apache2.4.59\\bin\\httpd.exe -d C:/wamp64/bin/apache/apache2.4.59'
[Thu Apr 25 15:28:37.561516 2024] [mpm_winnt:notice] [pid 4240:tid 328] AH00418: Parent: Created child process 7600
[Thu Apr 25 15:28:38.070181 2024] [mpm_winnt:notice] [pid 7600:tid 328] AH00354: Child: Starting 64 worker threads.
[Thu Apr 25 15:41:00.277844 2024] [core:alert] [pid 7600:tid 1256] [client ::1:50795] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:41:24.944202 2024] [core:alert] [pid 7600:tid 1256] [client ::1:50803] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:45:45.418797 2024] [core:alert] [pid 7600:tid 1256] [client ::1:50811] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:47:26.925758 2024] [mpm_winnt:notice] [pid 4240:tid 328] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Apr 25 15:47:28.967723 2024] [mpm_winnt:notice] [pid 7600:tid 328] AH00364: Child: All worker threads have exited.
[Thu Apr 25 15:47:29.827095 2024] [mpm_winnt:notice] [pid 4240:tid 328] AH00430: Parent: Child process 7600 exited successfully.
[Thu Apr 25 15:47:32.608347 2024] [mpm_winnt:notice] [pid 7684:tid 328] AH00455: Apache/2.4.59 (Win64) PHP/8.3.6 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Thu Apr 25 15:47:32.608347 2024] [mpm_winnt:notice] [pid 7684:tid 328] AH00456: Apache Lounge VS17 Server built: Apr 4 2024 15:03:17
[Thu Apr 25 15:47:32.608347 2024] [core:notice] [pid 7684:tid 328] AH00094: Command line: 'c:\\wamp64\\bin\\apache\\apache2.4.59\\bin\\httpd.exe -d C:/wamp64/bin/apache/apache2.4.59'
[Thu Apr 25 15:47:32.655221 2024] [mpm_winnt:notice] [pid 7684:tid 328] AH00418: Parent: Created child process 5088
[Thu Apr 25 15:47:33.141047 2024] [mpm_winnt:notice] [pid 5088:tid 344] AH00354: Child: Starting 64 worker threads.
[Thu Apr 25 15:55:19.215317 2024] [core:alert] [pid 5088:tid 1260] [client ::1:50822] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:55:20.188618 2024] [core:alert] [pid 5088:tid 1264] [client ::1:50821] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:55:20.352746 2024] [core:alert] [pid 5088:tid 1260] [client ::1:50824] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
[Thu Apr 25 15:55:20.570896 2024] [core:alert] [pid 5088:tid 1264] [client ::1:50825] C:/wamp64/www/Gestsup/.htaccess: Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration
- Capture.PNG (67.86 Kio) Vu 5883 fois
Pouvez-vous remplacer le contenu du fichier .htaccess avec le contenu suivant :
ErrorDocument 404 /error/404.html
Options -Indexes
<Files "composer.json">
Require all denied
</Files>
<Files "composer.lock">
Require all denied
</Files>GestSup: 3.2.64 | Debian: 13 | Apache: 2.4.68 | MariaDB: 13 | PHP: 8.5 | https://doc.gestsup.fr/
