j'ai bien retéléchargé le patch 3.2.34 et j'ai écrasé les fichiers.
Le résultat est :
site votre plateforme:
Fatal error: Uncaught Webklex\PHPIMAP\Exceptions\ImapServerErrorException in /var/www/html/saas/tstjulian/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php:306 Stack trace: #0 /var/www/html/saas/tstjulian/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php(380): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->readResponse() #1 /var/www/html/saas/tstjulian/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php(841): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->requestAndResponse() #2 /var/www/html/saas/tstjulian/vendor/webklex/php-imap/src/Client.php(575): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->folders() #3 /var/www/html/saas/tstjulian/core/imap_oauth.php(212): Webklex\PHPIMAP\Client->getFolders() #4 /var/www/html/saas/tstjulian/mail2ticket.php(165): require('...') #5 {main} thrown in /var/www/html/saas/tstjulian/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php on line 306
sur ma plateforme:
Fatal error: Uncaught Webklex\PHPIMAP\Exceptions\ImapServerErrorException in /var/www/clients/client4/web4/web/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php:306 Stack trace: #0 /var/www/clients/client4/web4/web/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php(380): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->readResponse() #1 /var/www/clients/client4/web4/web/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php(841): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->requestAndResponse() #2 /var/www/clients/client4/web4/web/vendor/webklex/php-imap/src/Client.php(575): Webklex\PHPIMAP\Connection\Protocols\ImapProtocol->folders() #3 /var/www/clients/client4/web4/web/core/imap_oauth.php(212): Webklex\PHPIMAP\Client->getFolders() #4 /var/www/clients/client4/web4/web/mail2ticket.php(165): require('...') #5 {main} thrown in /var/www/clients/client4/web4/web/vendor/webklex/php-imap/src/Connection/Protocols/ImapProtocol.php on line 306
j'ai restesté sur votre interface envoyée par MP, j'ai la même erreur. Vous dites cependant que votre interface est 3.2.33 mais moi j'ai bien la version 3.2.34 dans votre domaine fourni.
[Corrigé 3.2.35] Problème import mail IMAP
Pouvez-vous tester sur l'interface tstjulian avec la bal de test ?
De mon côté sur l'interface de test tstjulian avec la bal tstgestsup cela fonctionne :
- 2023-03-22 11_50_47_screenshot_gestsup.png (37 Kio) Vu 954 fois
Je viens de refaire le bouton importer sur votre interface de test et miracle moi aussi ça marche !! (Ce n'était pas le cas quand j'ai cliqué la dernière fois) !
Je viens de tester aussi sur mon domaine à moi avec la BAL de test (la même que sur votre domaine de test) et j'ai toujours l'erreur :S
Avez vous bien regénéré le token après le changement de bal sur votre serveur ?
Pouvez-vous indiquer la version affichée dans l'entête du fichier /core/imap_oauth.php ?
Tous semble correct pouvez retransmettre le message d'erreur sur votre serveur avec la bal de test ?
voici le message:
GESTSUP IMAP CONNECTOR v3.2.34
DATE : 2023-03-22 12:23:12
MODE : single
MAILBOX : tstgestsup@*****priv.fr
OAUTH SINGLE UPDATE REFRESH TOKEN : 0.AXQASn3jVY1tFk6Jajq7hn*****************
CONNEXION : OK
MODE : single
CONNEXION : OK
Je ne comprend pas pourquoi cela fonctionne sur mon serveur et pas le votre avec la bal de test.
Pouvez-vous donner accès à votre serveur de production en MP ?
